budsbud662
- Apr 15, 2008
- 66
My boat is a 1999 Warrior eagle 1891 full V walleye boat.
dry weight without motor is about 2000lb's
Last year i was running a 1996 Johnson 150 (non-fast strike) I ran a 19p aluminum prop and the motor spun 5400 RPM @ 45mph. I tried a 21p SS viper and spun 47mph @ 5300
This year im running a 1997 Evinrude 175 intruder (carbed) I was able to try a new prop and i like it with exception its actually slower then my old 150 setup.
The new prop is a mint condition 23 pitch ballistic currently the 175 with the 23 pitch runs at a top of 43mph @ 5200 RPM's
Man spec is 4500-5500 RPMS.
all three props listed above had excellent hole shots on my boat.
My question is, Why is the 23p SS on a 175 running slower then the 19p ALUM on a 150.
My next question is, I assumed id be able to do low 50 mph's with the 175 Is this a mere dream. i think the boat should run it easily.
Both motors had good compression during testing and ran great.
I tried raising the motor a hole and lost 4mph off the top.
any other ideas?
any other ideas?
