Re: VHF radio question (testing it)
First.
You need a [FONT=Book Antiqua, Times New Roman, Times]Restricted Radiotelephone Operator's Certificate (maritime) in order to use a VHF radio in Canada. You need to go through a Canadian Power Squadron for the course etc. It's $60, and three nights. Pretty easy as I passed mine last week with one mistake.
Technically, you should not be using the radio unless you are on the water (you can be fined for this) so it is hard to test it out. I guess you can turn it on and listen to the weather channel.
The newer units are much more useful as they can talk to a gps etc. and transmit your location in distress.
But without the Certificate, you shouldn't use it.
[/FONT]
