shred_monger
- May 14, 2009
- 1
Hi Everyone,
I'm new at all of this so I'll tell you as quick as I can .
I recently purchased a CD-18 5.5hp I beleive it's 1961
I purchased it early this spring and it was starting no problem.
I brought it home and started on the 2nd pull....
I ran it with a snorkle on and off for about 20 minutes at varios rpm with and without the trans engaged. Ran great.
The next weekend I took it for a test run at the local waterway.
It started up right away for about 3 minutes, then I think I flooded the motor out and tried starting for about 30 minutes on and off..
Since then I have not been able to get it to fire.
Both plugs are firing fine so I'm assuming the coils plugs and wired are ok.
Compression feels ok (though I have not actually tested it- I 'm use to 2 stroke dirt bikes)
Plugs are getting wet when I try to pull start .
They were a little dark when i first took them out so I cleaned them up and changed the mixture out the forums recommended oil ratio.....( I cant actually recall it as I'm piosting this thread)
Not sure when it was last maintained.
That's all I have to start...any help here would be greatly appreciated,
