This is a 9.5 Johnson seahorse. It has been sitting for a while so I want to fix it up. I tried the motor and it starts right up and did run but at only half speed. Runs very sporadic at slow speed, coughs and sputters, vibrates. I cleaned the carb and the motor still would not go above 4.7 miles per hour or idle around 2 mph. I adjusted the carb as described in the secret files, 1 1/2 turn out. This motor is on a 14 semi-v run about. New plugs, gas line, fuel pump No extra weight but me the gas tank and motor. Water discharge from pee hole is fine.
Yesterday I had the motor out on the lake and the wind came up and started to blow enough for me to head for the dock. The boat got side ways and I had to turn the motor real sharp, the motor hit the transom. As I was giving the motor the throttle it hesitated a couple of times, I gave the motor full throttle and it was like it was a new motor. It ran at full wide open throttle. Maybe a stuck jet or float or maybe a bad wire somewhere?
I need to replace the seal in the lower unit and figured that since I will be doing that might as well change points, plug wires and so on.
Where can I find the serial # on the motor? There are 2 little round disks on the top of the motor above the spark plugs with these numbers:
30958 and J37-64-397. There some numbers printed on the carb but they are not readable.
