  #1
Old June 6th, 2009, 08:09 PM
rld1017 rld1017 is offline
Default mercury lower unit oil leak
My 175 mercury lower unit has a heavy oil leak Seals and o-ring were replaced but it made no change. Could not find any damage in unit when it was apart and no water was in unit. OEM parts were used . can oil come from anywhere else like around water pump Ronnie
  #2
Old June 7th, 2009, 08:17 AM
Chris1956 Chris1956 is offline
Default Re: mercury lower unit oil leak
Ronnie. The gearcaser has seals at the driveshaft under the waterpump, the shiftshaft and the bearing carrier and propshaft. It also has gaskets on fill and drain plugs. The waterpump base has the driveshaft seal. If it is leaing out the water intakes, or not by the propsahft, that is your likely problem.
  #3
Old August 12th, 2009, 09:12 PM
What I found was the oilpressure check valve was not releasing pressure. When I took the oil cap off the tank a week after motor was run it was still under pressure. It was pushing oil out and flooding motor
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Oil leak from lower unit extramile Johnson & Evinrude Outboards 3 February 22nd, 2007 07:44 AM
lower unit oil leak sandspike Johnson & Evinrude Outboards 4 April 3rd, 2005 08:47 PM
Lower Unit oil leak duckinit Mercury & Mariner Outboards 8 November 16th, 2004 05:15 PM
85HP V4 Johnson Oil leak lower unit and water in oil darwinh11 Johnson & Evinrude Outboards 3 October 10th, 2003 07:29 PM
Oil leak from lower unit HarvMan Mercury & Mariner Outboards 5 April 21st, 2002 09:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
