I just finished replacing the water pump on my 1997 Evinrude 200. I thought I read just about everything there was to read regarding this procedure, both online and in the shop manual. I even measured the water tube to make sure it would mate sufficiently with the pump housing and had a helper to guide everything when we put the lower unit back on. Anyway, long story short... tested it on the muffs and water is literally pouring out from the lower unit seam. Not just a few drops -this is a real gusher! Is this considered normal or did I mess up somehow? Thanks in advance!
