need some help with 78 merc inline 6
wwatson
maybe someone out ther can help, I have been tearing the teeth off my drive gear on my starter:
JB
Re: need some help with 78 merc inline 6
Starter aligned with flywheel?
CharlieB
Idle timing tro advanced?
Partly seized cyl/bearing/bent rod, causing a very 'stiff' spot during revolution of the motor.
Remove the spark plugs and turn the motor over by hand to feel for any stiffness anywhere.
Connect a spark tester and timing light and check idle timing setting.
