I took the boat out for a spin just to see if there was a possible chance that the carburetor would clean it self out. The engine started fine and was running smooth until I approached the speed zone and I gave it the throttle. When I did, the engine began to have loss of power and eventually died. I tried restarting it and the engine would not turn over. I checked any fuses that I thought would be a possibility. No bad fuses were found. My batteries are new and connections are secure. When I got it home, I tried to start it and I could hear the click coming from the solenoid and that's all. It appears that I have two separate problems, the carburetor and now an electrical problem. Since it does not even turn over, what do you think could be the possible causes? Solenoid, starter or other.
When I prime the bulb gas leaks out under the hood and runs out from inside. I was told that it is a needle valve problem and that my carburetor needs cleaned. It was rebuilt last year so hopefully I will just need to clean it rather that buy any new parts. Also, I was told to make sure that the float is adjusted properly.
Help with the electrical problem now would be appreciated.
Thanks, MR
Thanks, MR
