Nivekt
- May 13, 2009
- 481
Hello All,
The problem first surfaced when the outdrive was in the down position. It would not tilt up. All I would hear is a clicking sound. I loosened the gear on the outdrive and manually lifted it up a few notches. After doing this the tilt motor was then able to fully bring up the outdrive.
Now that I have it in the up position I cannot get the outdrive to go down. Whenever I hit the switch to go down, I get the same clicking noise. When I try to tilt it up I can hear the motor running so I would assume there is nothing wrong with the motor.
Could it just be a bad solenoid?
I did search for other threads similar to my problem, but couldn't find one quite like mine.
Thanks
Thanks
