Well about a week ago i got stuck on a sand bar. Since then the Power trim tilt is not working at all. When i push the button to lift up or down not even a sound of the motor working. Before it was working fine. What could have happened to the trim tilt when i hit the bottom. <br /><br />I didnt hit hard at all. I cant check the prop untill i lift the boat.<br /> But i get no vibrating at all. So i think the prop is fine.<br />What should i check for?
