Frank Acampora
- Jan 19, 2007
- 12,004
About two weeks ago I bought an nice early 1980s Chrysler 50 for 80 bucks. Seller just acquired it with a lot of several other engines and just did not want to bother with it. Cosmetically it was in great shape and seemed to have no corrosion problems.
Finally, today I got to do some testing on it.
Once I wired it up and put fuel in it, it fired right up and settled into a remarkably smooth idle. Hot Damn! Not bad for an unknown engine.
BUT--Before I use it I decided to do my usual and change the impeller and lower unit oil.
The lower unit was bone dry, not even smell came out. Then I dropped it and lo and behold, the impeller was in decent condition BUT the P.O. had left off the bottom stainless plate. That water pump would have pumped nothing.
SO: Moral of the story? Assume nothing even if the engine appears in GREAT shape. Check everything that can wear or be changed. Tomorrow the fuel pump diaphragm gets changed and the carb cleaned.
The engine is already mounted on my 10 foot tunnel hull with a 10 1/2 X 14 bronze racing prop. Maybe I'll see what she can do this weekend.
