  #1
Old June 5th, 2009, 06:04 PM
shawpdx1 shawpdx1 is offline
Default 1966 18hp evinrude flywheel removal NIGHTMARE
For the life of me I can not get this flywheel off Ive done tons of them this one has me beat.
tryed puller
tapping and prying
heated it up
its been 4 days of trying for about 20min then I walk away
any secrets? the problem is I only have spark to one cylinder thinking a coil or points issue. there is not inspection cover on this flywheel
  #2
Old June 5th, 2009, 06:11 PM
bankerjohn's Avatar
bankerjohn bankerjohn is offline
Default Re: 1966 18hp evinrude flywheel removal NIGHTMARE
Can you tell if the crankshaft key has been partly or totally sheared?
__________________
1996 Evinrude 9.9 4-stroke
1995 Yamaha 115 2-stroke
  #3
Old June 5th, 2009, 06:12 PM
crxess crxess is offline
All you can do is keep at it. Keep the puller tight.
have someone life on the flywheel while you Smack the puller center bolt HARD. Tighten more and repeat. Even a fraction of a turn gain on the puller is heading in the right direction.
I had to use a ratchet strap around the flywheel resting against the head to hold mine enough to get a little extra oomph in the puller bolt.
You are not using the flat foot on the puller are you? might be to large in diameter holding the flywheel down.
  #4
Old June 5th, 2009, 06:16 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
That flywheel should be a snap to remove if done properly.
Puller must be the type that incorporates three (3) bolts that screw into the threaded holes surrounding the crankshaft.
Center puller spindle must be tightened down securely..... very tight!
A slight bit of pressure should be applied to the bottom edge of the flywheel to raise it off the play measurement.
The center pulley spindle should then be hit straight down with a great amount of force..... really belt it hard!
Any other type of removal attempt usually results in problems.
Applying heat was a mistake...... not to be done.
  #5
Old June 5th, 2009, 06:33 PM
yeah I have the 3 screws in the holes type puller even put liquid wrnch for days!!!!!!!! and it will not budge. everyone Ive ever done its a breeze little tap and lifes good this one could be a anchor motor to bad it was a good runner Im about done with it Ive walked away for the day maybe try again this evening
  #6
Old June 5th, 2009, 09:30 PM
F_R F_R is offline
Quote:
Some cretin probably put Locktite on it. Good luck.
  #7
Old June 5th, 2009, 11:53 PM
samo_ott's Avatar
samo_ott samo_ott is offline
If you're gonna walk away from it then it's time to really get rough! Try an impact driver on the puller. I've never tried it but hear it works. Or get a helper to really tighten it down while one holds.
__________________
Steve.
  #8
Old June 6th, 2009, 07:43 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i have had them take a week or more to come off. a strap wrench, to go around flywheel, and a cheater bar on puller wrench. tap center bolt with hammer, then tighten some more. i do it every couple of hours. they will finally pop, or the bolts pull out.
also make sure the puller center bolt is in line with the crank, a straight pull is a must.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1966 18hp evinrude engine pics? oldyellar Johnson & Evinrude Outboards 1 June 30th, 2008 08:49 AM
1966 Evinrude 18hp crownhoney Johnson & Evinrude Outboards 0 September 6th, 2007 09:47 AM
removing propeller on 18hp 1966 Evinrude adam246 Johnson & Evinrude Outboards 2 May 7th, 2004 07:33 PM
EVINRUDE 18Hp 1966 18602 Tom Malmquist Johnson & Evinrude Outboards 1 October 19th, 2003 07:17 PM
1966 Evinrude 18HP Fastwin jchacon100 Johnson & Evinrude Outboards 3 September 2nd, 2002 07:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
