Jeff-in-PA
- Dec 27, 2008
- 402
[history at top, question at bottom ]
In an attempt to get a working gas gauge on my 1993 Starcraft 240 Starfish pontoon boat, I've checked out the sending unit and gas guage as described in my previous thread http://forums.iboats.com/showthread.php?t=307300
I've purchased a NOS gas guage, a new sending unit and got new wire. I installed the gas gauge and the new sending unit ( seperately , checking for correct operation before trying the other unit). Still no reading. ( all electric work has been done with battery ground disconnected )
At the sending unit, the center wire is red and the ground is black & green. The green goes directly to the metal side panel of the boat from the sending unit itself. The red and black wires run to the console.
Due to Starcraft's twisting of the wireloom and placement over the tubes, I can not physically pull the wires out to visually follow them.
I ran new red and black wires from the sending unit up to the console. Looking at the back of the gas guage, I have reddish/pink wire for the sending unit wire, black wire at the center post and a purple wire to the other side with a pigtail for the 1/4" male plug for the lights.
Here's the question
To wire this direct --
Am I correct in assuming the sending unit wire ( red) goes to the post marked "sending unit", the black wire to the center post and leave the factory purple wire in place?
This would assume that the purple wire would power the sending unit ( right? )
Thank you
Jeff ( who's figuring out nothing is as simple as it should be )
Here's the question
Thank you
