Thanks in advance to all who respond. The seals are shot in the lower unit as an oily mixture of water and oil (more water than oil) ran out when going to change the oil. No metal shavings thank God. I ordered a seal kit to replace all the seals which i think contains seals for shaft and water pump. I have changed the water pump before no problem. My question is this. How hard is it to change the seals on the prop shaft. Does this shaft have to be pulled out or can it be done without pulling the shaft. Are there any special tools besides wrenches sockets etc, that I will need to change these seals. I have heard people say this is easy to do and will take only a few hours but I dont want to screw this up. If there are any diagrams that would be great. Thanks. Josh
