Re: 15 or 17 pitch on a 89' 125 HP Force?
Dmas, thank you very much for posting your new numbers for me, I appreciate that.
Now let's talk about your new prop, there is something wrong with it. Whenever you change from a higher pitch to a lower pitch you should always have an increase in hole shot and the acceleration should also increase from a lower speed to a higher speed, this is the normal way props work. Frank I will agree with the theory that you can have a possible loss of top speed, but you should not lose anywhere near 4 MPH from 34 MPH with the same make and model of prop with a 2" lower pitch change and the commensurate increase in RPM , because the RPM increase makes up for most of theoretical speed loss from pitch.
Dmas, I ran my numbers with the 17" Prop and the 15" prop, you had a loss of 4 MPH, but you also went from a prop slip of 19% with the 17" prop to a prop slip with the new 15" prop of 27%. That is not normal, when you go down in pitch normally you have an increase in diameter, and we did in this case as well, we had in increase in diameter from 13.5" to 13.75" which I assume is the Vortex prop, is that what you had before or did you have the Michigan Match. When you have an increase in diameter that means there is more blade surface area on the new prop, which means that the prop slip should go DOWN not UP, as has happened in this case.
The reason I use mathematics to figure out what prop pitch changes are to be expected is because it is Not empirical evidence. What we see when this prop loses 4 MPH is not what should happen, and there is a reason for that.
There is something wrong with this particular prop, I don't know what it is but it is a defect of some kind, believe me. I certainly make errors, ONLY if I am breathing. LOL But, this should not have happened.
I have made many prop pitch recommendations here, and anytime anybody uses the same make and model of prop and decreases the pitch there is ALWAYS an increase in hole shot and acceleration as well as a DECREASE in prop slip. Yours is exactly the opposite of that by your statements, and that is not the way it should be, that is why I say there is a defect in the prop, as well as my numbers show what has actually happened.
My recommendation is to take the prop to a reputable prop shop and have them put it on the pitch block and find the problem, and if you can't do that then sell it on ebay and buy another prop in the same model as you had before in a 15" pitch.
Here are my numbers and why I say there is a problem with this prop. You should have lost less than 1 MPH.
Prop Slip
H
