  #1
Old June 5th, 2009, 07:32 AM
JoeMac JoeMac is offline
Default 1998 90hp 3 cyl Mariner blowing blue smoke and dumping fuel in water after shuting of
Non-mechanically inclined person here with a Mariner motor that runs fine at first start-up of the day. Then on the next start, and every start after that the motor is hard to start, runs poorly, idle's rough and is shutting off at slow idle. Then you can smell and see gas coming out of motor somewhere, as there is large amout of it on the top of water around the back of boat. On next start you get large amout of blue smoke.
I've read some post's here about the older Mariner motor's having issues with a defective valve somewhere that is suppose to bled off when you shut off the motor. I guess the pressure that is developed to make the fuel/oil system work is not bled off due to this defective valve and that causes oil and gas to flood the engine and makes it run like the choke is on.
The reason I think this is my problem is when I start the engine for ist time of the day, it runs like a champ, 5,000 rpm's, gets right up to plane...etc. Then on shutting down, the gas spews out and it's a rough engine the rest of day. Next day 1st start it's back to running fine. Then cycles poorly again.
So I think this defective valve is my problem. My question is does anyone know what the name of the defective valve is. Can a layman like me fix it, or does it need to go into Mercery\Mariner motor repair guy? Thanks for any advice offered.
  #2
Old June 6th, 2009, 12:07 AM
Default Re: 1998 90hp 3 cyl Mariner blowing blue smoke and dumping fuel in water after shutin
After surfing all day I think I have found the part. A fuel pump check valve kit. Anyone replaced their rubber check valve for a plastic one?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
need help, gas dumping into #2 cyl and wont stay running Andy in NY Mercury & Mariner Outboards 11 May 30th, 2009 07:30 PM
1988 Mercury 35HP strange smoke plus dumping gas tigerbake Mercury & Mariner Outboards 3 October 7th, 2007 09:45 PM
1972 Johnson 9.5 blowing blue smoke jon1234 Johnson & Evinrude Outboards 4 July 7th, 2005 07:10 PM
1987 Mariner 3 Cyl. 90HP Starting Problems frednick1 Mercury & Mariner Outboards 2 August 2nd, 2004 06:32 PM
1995 90hp Mariner #1 CYL not working NORIBOR Mercury & Mariner Outboards 2 January 14th, 2004 04:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
