69fastback393
- Feb 18, 2009
- 7
i have a 30 mariner 79 or 80 model single carb.it had been sitting for awhile. i disassembled the carb and cleaned it,replaced the needle valve,cleaned the nozzle and main jet and every port or orfice i could see,replaced the fuel pump and it cranks and idles fine but when you put it in gear and open the throttle wide open it bogs.i can run it at 1/2 choke and it does fine.
am i missing something that needs to be cleaned? is there a method of soaking the carb.what are you guys suggestions.
