bought motor unseen and enigne runs fine on top end and at idle but when put into gear it wants to bog and die unless you pull choke and give it the gas. pulled plugs imedeatly after it dies and plugs are wet. seems to me like its flooding out when a load is put on motor. Compression is 90 psi on both cyclinders. had a mechanic look through carb and he said it looked fine
model # E15REDG
model # E15REDG
