Re: Sudden loss of spark/ trimmer
I cleaned the carb, put it back on and started it. The trimmer ran for a few seconds and died. I couldnt get it started. I put a little gas in the cylinder to jump start it and couldnt get it going. Finally I tested the spark with a light-up checker and got nothing. How do I troubleshoot this problem. The on switch is in the on position.
Help is greatly appreciated
Thanks
I'm not a professional mechanic so I usually go from simplest/cheapest to hardest when I look at these things on my stuff.
First thing to check is the sparkplug. Make sure that it is ok - read it too to see if you are running right.
Next, inspect the sparkplug wire for cracks/discolorations/etc.
I don't know your trimmer, so I can't say how to do it or what would be easier to do next - but I would check the switch (volt ohm meter/continuity tester), then trace things to the coil or whatever you have that generates spark. I'm thinking you have a loose/cut/damaged wire if it's not the sparkplug based on your description.
