My trim cylinder end cap worked itself loose, I lost all the oil. It looked like it unscrewed itself most of the way and then popped off because I seen a little bit of shavings there. I tighted it back up. I am new at this and also found the piston that the trim unit uses for up and down and 2 bolts snapped off and the other 3 twisted and will break. I don't know if this can be fixed or not. I am sure I can bring the cylinder in to get fixed at a shop somewhere but not the piston part. I don't know. Does anyone know where I can find a new unit. Used or rebuilt? model# x1258F8C serial#x1651. Any help would be appreciated. this picture is like my unit but found this one on ebay to use as example. THis one looks a little bit used up.
