Hi everyone, sorry to bring this up again I just really want to make sure that I have this correct before I order anything (soon I hope). I know I?m probably over thinking it and making it more complicated than it needs to be (like usual) but I know you guys can set me straight.
I am still trying to decide between Epoxy and Poly, I have a pretty good idea of how I would do it with Poly so now I want to understand how it would work with Epoxy so I can try to decided which method would best fit my project.
So my question is does this sound like a workable layup schedule for a 15ft tri-hull using Epoxy resin:
Transom and stringers:
Glue transom to hull outer skin with Epoxy paste
4? tab of 18oz roving (2? on hull)
8? tab of 18oz roving (4? on hull)
complete cover 18oz roving (6? on hull)
Sole:
Coat bottom with Epoxy (should I also use cloth?)
complete cover 10oz cloth (Or would a different cloth/roving be better?)
Would this work? Am I missing anything or is there a better combination of materials? Is this enough glass or should I add a second complete cover on the transom and/or stringers?
Sole:
