I swapped out a 1981 Mercruiser 470 with a 1987 470 everything looks good except the exhaust manifold does not line up with the exhaust pipe. Do they make an off-set elbow for this? Or do I have to use the complete exhaust manifold assembly from the 1981. The 1981 has a 90? elbow that lines up with the exhaust pipe. The 1987 has a 45? elbow and is approx 3" in front of the exhaust pipe. I sure would like to use the newer exhaust manifold if I could get it to work. Any and all help would be greatly apreciated.
Thank You,
Craig
Thank You,
Craig
