jes100fish
- May 7, 2009
- 37
I can't keep the engine running. I cleaned the float bowl; this is making it easier to start. Disconnected the fuel line from the fuel pump and cranked the engine - gas is coming out but not a steady stream. Which part do I buy to replace the fuel pump.
If I pour gas into the carbuerator it runs for a few seconds and same happens if I put it into the spark plugs. Can't keep the engine running. I replaced the entire fuel hose, bulb and fittings with a new one - entire section from fuel tank to fuel filter. Bought new gas tank and I'm using new fuel.
Any help would be appreciated.
