I have done my searches and used the prop selector tool. Before I buy a new prop I thought I would run it by here first.
Currently @ WOT
RPM 4450
Mercruiser 3.0L
2008 Discovery 195
21" prop 3 blade aluminum
Need something better for skiing/wakeboarding etc.
Would an 18" 4 blade aluminum work or would it have too high of RPM?
Doing my own calcs
drop of 3" = +600 RPM
change from 3 to 4 blade = -150
New WOT to be ~4900 which I do realize is slightly over the reccomended RPM. What have others found as I am sure with all the 3.0L in use someone must have tried this in a semi similar situation.
Also I have SX smart tabs to put on, do they effect RPM at all. I guess I should install them prior to buying a new prop but I will be in the states this weekend and well things are cheaper there and would like to get one this weekend.
Thanks,
Currently @ WOT
RPM 4450
Mercruiser 3.0L
2008 Discovery 195
Doing my own calcs
Thanks,
