  #1
Old June 3rd, 2009, 11:31 AM
johntg3 johntg3 is offline
Default which motor for pontoon
i currently have a 90hp 2 stroke yamaha on a 22f/c G3 pontoon. i am wanting to upgrade my motor for more Hp and better economy.I have a choice between a 115 4 stroke yamaha and a 2 stroke injected 115 nissan both 2010 models. any suggestions.
  #2
Old June 3rd, 2009, 11:51 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: which motor for pontoon
yammy, no brainer.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old June 4th, 2009, 12:23 PM
does anyone run either of these motors that may be able to give me some pros and cons.
  #4
Old June 4th, 2009, 02:13 PM
rrhodes's Avatar
rrhodes rrhodes is offline
+1 on the Yammy
IMO Honda and Yamaha are the top motors out there
The only new 2 stroke I would buy is the Etec
__________________
Rick
2008 JC Neptoon 25TT
115hp Honda 4-stroke
2007 Suburban LTZ
Lake Murray, SC
  #5
Old June 5th, 2009, 12:00 AM
lmuss53 lmuss53 is offline
If the Nissan is direct injected and works like the Optimax or Etec models it is a good candidate for on this boat. The direct inject 2 stroke is lighter, just as economical, and will get the same power to the water as quickly or quicker than the 4s. The weight difference is what would have me leaning toward the 2 stroke. If the warranty is similar and the dealer has a good reputation and is near by I would not hesitate to put the Nissan on my boat.
If I were shopping fo a new powerplant for my boat I would buy the max HP in an Optimax or Etec. If the Nissan is a comparable motor to them I wouldn't shy away from it.
If by injected on the Nissan you mean oil injection to mix fuel and oil to run through an old fashioned carbeuretor, then I would say the 4 stroke is what you want. You don't want to mess with a carbuereted 2 stroke motor in this day and age.
  #6
Old June 5th, 2009, 10:11 AM
the nissan is a fuel injected and oil injected 4cyl. 2 stroke.the dealer tells me it will outperform the 4 stroke yamaha.
  #7
Old June 5th, 2009, 08:10 PM
Interesting reading from the Nissan website on DI 2 strokes.
http://www.nissanmarine.com/tech_talk/tldi_faqs.html
  #8
Old June 6th, 2009, 10:56 AM
SoulWinner SoulWinner is offline
I have a Mercury 115 four stroke on my 20' Crest. It is a Yamaha motor that was made in Japan. I gotta tell ya, I love it. I will NEVER own another two stroke. It's quiet, doesn't smoke, doesn't put oil from combustion in the water, no fooling with adding oil to the oil tank, no worrying about whether the oil injection is going to get clogged and stop injecting oil while we're under way, etc. I love this motor. This is my fourth boat and first four stroke and I am sold on it.
When I got the boat it was propped all wrong, and with some help here on iBoats I got the right prop and it is an absolute joy to own. I was the first on the river here to have a big four stroke on a pontoon, now I see them all time. I know that the Etec is a good motor, but after owning this four stroke, I don't see myself ever having another two stroke.
My advice, get that Yamaha. Get it now. You will love it.
  #9
Old June 6th, 2009, 11:38 PM
Frankenstien Frankenstien is offline
Quote:
Originally Posted by SoulWinner View Post
I have a Mercury 115 four stroke It is a Yamaha motor I will NEVER own another two stroke. It's quiet, doesn't smoke, doesn't put oil from combustion in the water, no fooling with adding oil to the oil tank, no worrying about whether the oil injection is going to get clogged and stop injecting oil while we're under way, etc. I love this motor.
Taken slightly out of context... but what Soul Said....
  #10
Old June 8th, 2009, 08:15 PM
Silvertip Silvertip is offline
But you still need to change oil and filter and dispose of it so those engines are not as environmentally clean as one thinks. At wide open throttle the noise levels of modern two strokes are within a very small margin of the four strokes. All you need to do is check performance reports. A two stroke makes a different sound than a four stroke so most folks equate that to quietness which it is definitely not. No -- I'm not biased. I have both technologies. The four stroke is much more service intensive. Valve adjustments, oil and filter changes, etc. Doesn't make them bad motors, but it does not make them any better or worse than DFI two strokes. And a DFI two stroke will almost always out holeshot an identically equipped boat with a four stroke motor of the same HP. I happen to prefer a four stroke on my pontoon since it is not required to run at high rpm nearly as much as my V-hull. On it I prefer the hustle of a two stroke.
  #11
Old June 9th, 2009, 07:07 PM
TooManyQuestions TooManyQuestions is offline
My two cents worth:
Im no where near the experience level of others on this post, but I will say that the 115 2 Stroke Evinrude Etec that I got for my 22ft has been great. Now having said that, I have no experience to compare it to other than a small 14ft Starcraft with a 40HP Johnson that I used for 3 years.
But I must say that I talked with two mechanics and several boat owners who said the 2 stroke has less parts and therefore less to go wrong with it.
And I always heard that the Evinrude was "bullet proof." As folks on here may remember, I was struggling between the Mercury Optimax and the Evinrude. I even bumped up the HP after talking with a couple of people.
And I had a "Made in America" requirement as well. Im sure some engine componets were shipped in from overseas though.
I could use some advice on prop and whether Im "propped correctly." I need to do some measurments and report back, however I assume (remember the first three letters of the word though) its a standard prop for the engine (although I was told its aluminum, which is better than steel).
And also, one of the posters on here refered to the oil injection resevior (sp). What should I watch for on this issue.
Glad to contribute, but I still have ...
Too Many Questions!
(lol)
  #12
Old June 14th, 2009, 01:42 AM
trooplewis trooplewis is offline
two-strokes and pontoons go together nicely. The low-end torque of the 2-stroke would be my first choice.
I had a 250hp Evinrude and it pulled way stronger than any 4-stroke outboard OR inboard teha I have ever been on in that horsepower range.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
lowering motor on pontoon leohohner Pontoons 4 November 6th, 2008 09:59 AM
motor on pontoon boat? ssjoanna22 Boat Topics and Questions (not engine topics) 8 January 12th, 2005 04:57 PM
What size motor for pontoon sunedog Non-Repair Outboard Discussions 4 August 12th, 2004 04:53 PM
Pontoon needs electric motor!! kraky Electrics, Electronics and Trolling Motors 5 August 16th, 2003 09:48 AM
Pontoon needs electric motor!! kraky Non-Repair Outboard Discussions 3 June 28th, 2003 05:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
