Hi!
The case is solved. After sevreal testing and fixing the flaw was in spark plug cables and in the reeds changed mainly
Other parts given maintenance:
In one piston had broken rings so they were changed.
One carburetor had some dirt on it, when cleaned showed 20% increase in speed still laced power on acceleration.
We got a hint to test the switch box spraying the cool spray on it, so if there is some tiny fractures the hull of the switchbox will compress and the fractures become intact and the switch box will operate normally. When trying to do this while testing the boat on lake I felt a electric shock while touching the case of the engine. It was a rainy weather but there shouldn`t be any electric leaks on the hull.
When checking the spark plug cables one of them had fracture on it so that there was electric leak on a nut to the hull of the engine. Now when changing cables so that the broken one was not able to touch the nut in the hull engine worked perfectly. 65 km/h
