scrampbell
Thread starter- Joined
- Feb 25, 2009
- 108
Hi all,
I'm thinking of buying my first boat and I need some motor advice. I've been told that one of the most important factors is the condition of the motor. That being said, the seller initially said the compression was good on this older 70hp Johnson (I'm guessing early to mid 80s by the picture), but when I mentioned that I would want to check the compression again before the final sale, he backpedaled a little bit...
He said he had the compression checked last year and that the compression was good on #1 and #3 cylinders, but that they either couldn't get to or couldn't get a reading from #2. I wasn't real clear on exactly what he was saying except that it sounded like bs. So...
Question #1: How well would the motor serve me if in fact 2 out of the 3 cylinders are good right now? Could I expect it to perform as about a 45hp or so? Could I use it as is?
Question #2: Are there specific questions that I should ask to asses how broken the cylinder #2 is? I wouldn't mind working on it if there were a way to determine if it were fixable.
Thanks!
Thanks!
