Re: Hummingbird GPS + Depth Finder for beginner?
Yes, not because they will prevent you from hitting anything, but they are very useful tools if used properly. The GPS for obvious reasons for anyone that has been out after dark, it makes locating that dock you launched from in daylight much easier to find. You'd be amazed how hard it is to find your way in the dark on the water. The fishfinder has obvious uses for anyone fishing, but even when just cruising around it gives you a clear picture of the structure below your boat, the reason it won't prevent you from hitting anything is because the transponder for the fish finder is mounted on the transom (back) of your boat. So by the time it sees it, you've hit it. That said you learn the waters you spend most your time on, and you remember where the low areas are.
Ian
