  #1
Old June 1st, 2009, 09:49 PM
Whitebear2009 Whitebear2009 is offline
Default 1957 Evinrude Lark short-to-long shaft...
I have a 1957 Evinrude Lark 35hp and I think it is a short shaft, but am not sure.
When mounted on my boat, the distance from the top of the transom to the point of the 'bullet' (horizontal with the prop) on the lower unit is 24". I have a 83' Evinrude 20hp and the distance is 27.5" and it works on my boat just fine.
The 20hp works just fine but the 35hp does not sit deep enough in the water.
1) Is my motor a short shaft @ 24" or a long shaft?
2) What motors can I 'switch out' lower units with?
3) Where can I get a longer lower unit?
Thanks!
  #2
Old June 2nd, 2009, 11:49 AM
lindy46 lindy46 is offline
Default Re: 1957 Evinrude Lark short-to-long shaft...
The long shaft has a 5 inch extension piece which bolts on between the lower unit and the leg. pretty obvious if it is there or not. The lower units on the 1957 35hp were pretty unique and only interchange with a 1956 30hp. If it's a short shaft, to convert to long shaft you'll need the 5 inch extension piece I mentioned earlier, a long drive shaft, a long shift rod coupler, and a water tube extension. There is also a large vertical bolt which sits at the very back of the leg which bolts in from the top. You'll need a longer one of those.
  #3
Old June 2nd, 2009, 12:32 PM
jasper60103 jasper60103 is offline
Also, you may want to shop antique outboards (http://www.aomci.org/cgi-bin/yabb2/Y...ard=Webvertize) or ebay for parts. Also, you can place a free ad on antique outboards for the parts you need.
__________________
'77 Crestliner Voyager Dlx 16, '81 Johnson 25hp
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
convert long shaft to short shaft on 40 horse evinrude selectric cjbro101 Johnson & Evinrude Outboards 5 November 12th, 2008 07:49 PM
1978 70Hp Evinrude Lower Unit Long Shaft or Short Shaft HBF4 Johnson & Evinrude Outboards 3 April 23rd, 2006 07:10 AM
converting evinrude 1984 9.9 long shaft to short shaft alan5505 Johnson & Evinrude Outboards 8 February 28th, 2006 04:58 AM
25 HP Evinrude long shaft conversion to short shaft P. S. Johnson & Evinrude Outboards 1 June 3rd, 2003 10:15 AM
Evinrude Short Shaft to Long Shaft Question. thebigbuck Johnson & Evinrude Outboards 8 March 12th, 2003 11:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
