Lower unit oil...4.3L V6 Merc I/O
prc03sx195
I was wondering if it is required to change the lower unit oil on a yearly basis? What type goes in it and what is the procedure? Thanks
paul
allinmygarage
Re: Lower unit oil...4.3L V6 Merc I/O
If it is the Alpha one in it needs 2qts of Mercury ?High Performance? lower unit fluid ? not the ?Premium?.
I would say yes do it once a year.
It is super easy. Pick up a lower unit pump and a marina for about $10-$15. I would also recommend buying two lower unit washers. They are under $1 a piece and good to prevent leaks.
To change the fluid - Put the lower unit in the down position. There are two dime size flat head screws / bolts on it. One at the very bottom back of the lower unit and the other at the very top. To drain simply remove both the screws. The fluid should be slightly blue looking. Check for water in the fluid and make sure the washers came out with the screws.
To refill - The pump you bought will screw into the bottom hole. Pump the lower unit oil until fluid starts to come out the top hole. Next put in the top screw and don?t forget the new washer with it. The top one will create enough vacuum to remove the pump and not cause a complete mess. Just remove the pump and put the remaining bolt back in with the washer.
That?s about it. I just did it last weekend and it was super easy.
allinmygarage
Almost forgot. I would also pick up a grease gun and hit all the zerk fittings with some grease once a year.
Changing the lower unit once a year is very cheap insurance.
prc03sx195
Can this be done without a pump kit?
paul
Aviator5
I've done it once, not worth saving $10.00 on pump, besides oil has to be in the bottle with the spout.
allinmygarage
Someone else might have to field that question.
I know for my small evinrude I use tubes of lower unit fluid to fill it. I am not sure if you can get lower unit fluid for your boat in tube form.
I have only used a pump on my 4.3 merc alpha 1 lower unit.
I would just get the pump though. The pump is basically the same as a soap dispenser. It just screws on the top of a quart of oil and the hose screws into the lower unit. Then you just pump it about 50 times until it is full. Takes almost 2 quarts.
bhammer
Ensign
Is it a Alpha 1 Gen 1 or Gen 2 drive? Do you have a remote drive lube monitor in the engine compartment? If so, you need to make sure that gets filled as well. Dowload the manual for your drive and it has step by step instructions. Yes, buy the pump. Often times, you can get it along with a qt of the lube.
The links are in the Adult's Only Stickey in the Merc Forum or here:
Service Manual #6 R, MR, Alpha I outdrives 1983 to 1990
Must open each section individually to save.
http://www-alt.mercurymarine.com/mne...l/6/6covr3.pdf
Service Manual #14 Alpha I Gen II Outdrives 1991 to present
http://www-alt.mercurymarine.com/mne...14/14cover.pdf
prc03sx195
bhammer, Your links don't work and I cannot find it any other way. Thanks
paul
Ayuh,.. Yes they Do....Ya gotta Wait for 'em to download...
This_lil_fishy
Master Chief Petty Officer
Ayuh, they don't. Seems the site has been moved. You may still have them in cache Bond-o. If you go to the home address it redirects you to mercurymarine.com.
Ina
bhammer
Ensign
paul
Okay, try here, at the main page. You will have to find the correct ones for your engine / drive. http://forums.iboats.com/showthread.php?t=251571
It will take a while to download them before they open.
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/6/6covr3.pdf
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/14/14cover.pdf
Gary H NC
If you right click the link and do save it will download in a different window..
Faster that way but they are huge files and still take some time.
Ayuh,... There's Nothing wrong with the manual links if accessed from the Adults Only section in the Motors, I/O forum....
Same links bhammer reposted....
The links in bhammer's 1st post must be corrupted....
