Mariner 60hp mid range power loss
Hi All,
this is my first post - I must say that this is an excellent site!.
I have a problem with my 1989 60hp Mariner/Mercury which I could really do with some expert help. I use the engine at sea on the back of a 17ft Broom speedboat.
The problem is that above 8kts, just as the high speed coil engages the engine bogs down and stalls. If I push the throttle fully forward quickly from low revs the engine responds and runs at WOT without an issue until I throttle back to medium speed then it bogs and stalls. I am hoping that someone will recognise this strange behaviour - low speed ok, medium speed stalls, high speed ok.
Within the last 2 years the engine has had a new high/low speed coil & new switch box fitted, I have replaced the plugs with no change in behaviour.
Does this sound like a timing issue?.
Any help would be gratefully received.
Kind Regards
Eddy
