Re: please help!!!250 merc mariner wont start
I have a 98 merc 150, had and having still the same problems, thought it was my carbs but took it to my mechanic and he took out the water/fuel seperator and it was full of water. Replaced it with a new filter with clear view bulb on bottom and drain for the water and I emptied out most of my tank that had the ethanol in it, it seems ethanol turns into water within 1 week sitting. I now had the same problems agan, it will start for the few minutes in idle then shut off. I will again drain some fuel, add fuel stabilize(STABIL) ALSO there are a screw on each set of carbs 3 total that you can take out and let the water drain out. I am going to do that also. Let me know if anyone is trying this. it works, just get that ethanol outta there and put non-ethanol.
