  #1
Old June 1st, 2009, 10:50 AM
Leyland Leyland is offline
Default Oil leaking from exhaust -89 6hp Evinrude
Hi, I'm new to the forum.
Friday night I purchased an immaculant condition 1989 Evinrude 6hp 2 stroke, it looks like new & starts first pull (tested in garbage pail with water when purchased). Upon getting home I put the motor on the stand, Sunday I noticed dark (black) oil leaking from the exhaust port just above the propeller. at first I didn't think anything of it but I don't recall my 9.9 ever leaking like this... a little water maybe but not oil. The previous owner said he just changed the oil last week & tried it out last saturday... (he was selling because it was too small for his new boat)
Any ideas???
  #2
Old June 1st, 2009, 11:01 AM
tx1961whaler tx1961whaler is online now
Default Re: Oil leaking from exhaust -89 6hp Evinrude
Perfectly normal. It's unburned 2-stroke oil that gos out of the exhaust.
  #3
Old June 1st, 2009, 11:04 AM
crxess crxess is offline
From the exhaust port it is likely excess unburnt oil from idling or running on muffs. Motor will not burn away all the oil under those conditions.
Should clear after a run. If not the top seal in the gear case for the down shaft could be leaking.
  #4
Old June 1st, 2009, 11:10 AM
I'll get it in the water & check it again after... The motor is very clean & probably only been in the water a couple of times so worst case, maybe that seal dried out!
Thanks for the help
  #5
Old June 15th, 2009, 02:07 PM
ShaneC ShaneC is offline
Did you ever get out to the water? Just curious if you had futher problems!
I noticed last night after getting my 1974 20HP Merc running that is had this very dark oil leaking out between the propeller and lower unit where the two meet. I have just changed the foot oil and it has not even been in gear since the change. This oil didn't look like foot oil much too dark and a thick.
  #6
Old June 15th, 2009, 08:39 PM
Home Cookin' Home Cookin' is offline
Master Chief Petty Officer
I noticed black oil leaking from the lower unit/prop for the first time in 20 years on this motor. Then I had some black from the upper exhaust ports, and noticed a lot of black oil out the prop when I was having trouble starting. Figured I might be running too rich a mixture especially after reassurance from our friends on this forum that it was unburned oil and not a problem. They also pointed out, correctly, that lower unit oil will either be brown (clean) or milky/gray (water intrusion), and there is no crankcase oil like in a car.
Then the motor died at high speed; restarted once and died again. Mechanic found water in the cylinders, probably from a failed exhaust port baffle. It's beyond repair (1988 70hp Johnson). Makes me wonder, though, if those were signs, and if it were a newer motor, I should have taken it in rather than run it.
Thoughts from the experts?
__________________
A man of constant boat tinkering.
  #7
Old June 20th, 2009, 11:52 PM
scottzfx scottzfx is offline
Must be the day to find the unburnt oil. I just noticed the same thing on my '75 115. Thought it was a leaking seal. I just ran it on muffs yesterday to clear it and run out the gas when I got home and then tilted the motor up. When I put it down today, I saw the oil running down from between the prop and lower unit. It wasn't much and it was definitely black, not brown. Thanks for clearing that up!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
89 Mariner 2 stroke 60HP Gas leaking from exhaust? armentroutkt Mercury & Mariner Outboards 3 May 1st, 2008 01:35 PM
oil leaking out of exhaust dmented692006 Yamaha & Suzuki Outboards 1 March 27th, 2008 01:50 PM
Oil leaking down exhaust housing. Melvin Hatcher Johnson & Evinrude Outboards 8 August 25th, 2007 10:31 PM
evinrude 6hp leaking oil... crotter Johnson & Evinrude Outboards 5 June 25th, 2007 04:54 AM
oil leaking from exhaust port chrisandrew69ss Force & Chrysler Outboards 3 May 29th, 2003 08:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
