  #1
Old June 1st, 2009, 01:24 AM
drwalleye drwalleye is offline
Default Transom question - Grumman 16ft Aluminum Boat
I've recently purchased a 1993 Grumman fishing boat that has been very abused in the past. It's been left to sit in the rain for quite a few years and has had multiple owners it appears...
Going into it, I knew the deck was going to have to be replaced, and as I started the process of re-doing the floors, I was referred to these forums by a friend to help answer some questions.
After removing the first layer of rotten wood, I noticed that they had just put a second floor on top of the original. What a mess... Anyway, now that I've figured out how much work the floors are going to take and now how nice the boat is going to be when it's done, I've started to wonder about the transom.
The transom cap has been replaced in the past (not sure when), and they did a terrible job using very thin tin and then just sealed the heck out of it.
It seems that there is a lot of info on replacing the transom in these forums, but I couldn't find anything about if you can just buy replacement caps or if they need to be custom made? I also would like to get matching corners for the transom, any idea where to go about getting/ordering them?
Thanks for any info you can provide!
  #2
Old June 1st, 2009, 02:15 AM
danond's Avatar
danond danond is offline
Default Re: Transom question - Grumman 16ft Aluminum Boat
Caps and corners are tough. Some people have had them made (created custom molds). Caps aren't as hard - it's just bent stainless. You can do that yourself, or take it to someone and have one bent for you.
Trying to find replacements will be a waste of time. Easier to have them made!
__________________
1989 Starcraft 171S Select "Cap'n Crunch" / OMC Cobra 4.3 V6 / 432APRMED
If you're going to keep that OMC Cobra, please for the love of everything good in the world, get an OMC factory service manual. Not a Clymers, Not a SELOC. You can find them on eBay.
My boat repair website: http://transomfix.dcpolk.com
  #3
Old June 1st, 2009, 06:51 AM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
[/IMG]
Welcome to iboats.
Abuse and aluminum boats goes hand in hand. That is a good point...... the aluminum boat will normally recover nicely.
There are some really nice aluminum boat conversions in out completed project section that you should look at. http://forums.iboats.com/forumdisplay.php?f=407
The transom cap is normally made of very thin aluminum and if your cap is tin .... I would replace it asap. Aluminum is very prone to galvanic corrosion and tin can set that reaction off which causes cancer in the aluminum. I have never seen caps made from stainless steel but I guess if you wanted to make one it might be extra work.
New wood over old wood usually works for a season and it is a band aid repair. It is time to rip out the old and install the new. You will need to see what is under the wood and decide your future from there. Regardless of what you use ....... it will have to be sealed up tightly from the water.
Keep in mind the new pressure treated plywoods will react with the aluminum in the hull so ask prior to purchase.
Look at the hull when it is stripped...... rivets should be re-bucked (tightened up) and sealer (gluvit) applied if needed.
We have more aluminum boat restoration expertise here than can be found anyplace else.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #4
Old June 1st, 2009, 09:05 AM
5150abf's Avatar
5150abf 5150abf is offline
Ya, people do some funny things to boats.
Recovering a floor is almost inexcusable, it was cheap and easy and made the problem go away, for a while.
Decks on aluminum boats are pretty easy although I am pretty sure you will find waterlogged foam when you pull the deck off but even that isn't to hard to fix.
Maybe try a boat salvage yard for corner caps, you should be able to find some proper cast ones and those are pretty interchangable, the ones that are on it are next to worthless, they didn't do too bad of a job on the cap though, it pretty tough to bend channel like that, is it galvanized sheet?
See if you can find some thin aluminum sheet to make some new caps out of, I think you are on your own with that though, proabably cna't be had at a salvage.
Looks like a pretty recent job on the transom so I would see if it is okay before replacing it. maybe pull the cap and see what is under it.
Should be a really nice boat when you are done.
__________________
GO IRISH!!!!
  #5
Old June 1st, 2009, 09:23 AM
tmcalavy tmcalavy is online now
Crawl in there and poke at the transom with an awl...it should be solid, not mushy or soft. With the homemade tin cap/edge, it may have already been replaced...check it twice because you found a band-aid patch on the floor. Transoms in that kind of boat aren't hard to do...hardest part is getting the old one out and that's not too bad if its rotted and soft.
  #6
Old June 1st, 2009, 11:04 AM
Thank you guys for the quick responses! I removed one of the corners and was able to get a quick feel of the shape that the transom wood is in. It doesn't appear to be rotten as far as I can tell. I do happen to know a guy who runs a machine shop, I'll have to see if he can fashion me a new cap and some corners.
As mentioned above, there was some water-logged foam underneath the old floor. But to my surprise, it was only the back 2-3 feet or so that appeared to be soaked or saturated. I imagine the angle the boat was stored in when it was left to sit with water in it played a role.
From what I read in here, it makes the most sense to re-do all of the foam if it's water-logged. After the purchase of all my materials, I hate to add more work and money to the project. But I also hate to do things halfway and cut corners. I plugged a few holes in the back of the boat this weekend that I knew were causing leaks. I'm going to get it into the water sometime later this week to check for additional leaks. If it stays dry, I'll leave the old foam in. (which has dried out considerably in the past week or so that the floor has been off of it) If water seeps in, I'll be tearing the foam out to find the leaky rivets/seams and seal them before I put the new floor and carpet in.
I didn't take too many pics to begin with when I started, but I'll have to start a thread and post the progress I continue on. Thanks again for your help!
  #7
Old June 1st, 2009, 12:24 PM
gunner1's Avatar
gunner1 gunner1 is offline
Instead of taking the boat out on the water to check for leaks you could do what I did and simply take a hose and fill the boat to the water line. That way, you can get under the boat to visually check for leaks and mark them with a Sharpie for later repair. If you do do this, just make sure yo don't put in too much water.
__________________
Visit my project page. http://www.shareaproject.com/pages/p...,p,416,00.html
  #8
Old June 1st, 2009, 06:33 PM
I did try this to begin with. I knew the boat had a few leaks somewhere, because it was taking on water last fall when I first got the boat and just wanted to launch it to try it out.
I used a hose and ran water into the bottom of the boat (I didn't fill it all the way to the waterline though because water came streaming out of 2 rivet holes). The only leaks I could find were 2 holes that were drilled through the transom to mount a depth finder or some other piece of equipment that were not sealed or the material used to seal them didn't hold. If you strain your eyes at the first picture I posted, you'll see that there is a number of rivets (~20) that someone had put into the bottom of the transom and sealed. So I removed them and sealed it all with good old JB Weld.
I have at least 4 small lakes within 10min of my house, so it wouldn't be too tough for me to just run to the lake for a few minutes to test it out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
16ft Aluminum rivets sparky15 Boat Restoration and Building 12 April 24th, 2009 07:16 AM
'64 16ft OMC boat, transom is mush markedman Boat Restoration and Building 7 March 21st, 2008 07:59 PM
1961 aluminum 16ft lonestare fishing boat beaverman Lonestar 1 April 30th, 2007 07:01 PM
1994 Grumman 14ft aluminum deep vee skmag357 Grumman Boats 0 March 8th, 2007 11:02 AM
Transom in Aluminum Boat Question Bass Runner Boat Restoration and Building 7 May 19th, 2004 02:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
