Re: Honda Cold Starting
360Ginger-
Hondas are noted for starting with a just few pulls/cranks. If your's is hard to start look for causes like throttle position, choke, fuel bulb, and ignition. (Remember with 10% ethanol in the gas, water does collect easily and they don't run on water. A water separator/filter is a must). Follow the start up procedure in your owners book and it should fire right up.
BTW; My friends Yamaha starts hard if you don't follow the correct starting procedure. My old 1997 9.9 4 stroke Honda starts (cold) with two pulls every time when I follow the start procedure. About a quarter pull when warmed up. Only when cold it takes a few seconds to feather the choke and then it idles like a Swiss watch.
Your dealer may be able to help you find the "fly in the ointment" if you've checked all that out and it still doesn't run for you. Good luck!
