  #1
Old May 31st, 2009, 01:24 PM
stangadam stangadam is offline
Default 93 60hp evinrude starts&stalls
93 60hp starts stalls then runs for a while popping sound while it runs like a dead miss changed plugs coils cleaned carbs runs a bit better with lots of choke a soon as put in water starts and stalls constintly very hard to keep running vro disconnected does anybody have any ideas of what i could be missing any ides of what the psi should be.
  #2
Old May 31st, 2009, 03:39 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 93 60hp evinrude starts&stalls
very possible flywheel woodruff key is sheared, throwing timing off a bit.
PULLING FLYWHEEL
you need a harmonic balancer puller, you need 3 - #8 harden bolts, that fit the 3 holes in your flywheel. standard hardware store bolts will strip out, causing more problems. loosen the flywheel nut, leaving it on so it protects the thread. thread the bolts in 7/16 of an inch. then tighten the puller, adjust so it has a straight pull. now tighten the puller, rap the center bolt with a hammer, then tighten some more. you may have to let it sit over nite, and repeat in the morning. this is a compression fitting, it will eventually POP!!. do not loose the woodruff key that goes in the groove of the flywheel and the crank shaft. then installing the flywheel, it has to be totally clean, no oil, woodruff key in place. then torque the nut to the specifications for your particular motor. if you do not do this, the woodruff key with shear, and you will be repeating these steps.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old June 4th, 2009, 09:11 PM
thanks for the tip i will be trying this on the weekend sorry for not thanking earlier computer was messed up every piece of advice is appreciated hard to get info here in small towns of ontario canada
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
93 150 Evinrude Tracker stalls when throttled up OMCDano Johnson & Evinrude Outboards 8 September 29th, 2008 09:10 PM
60hp 1987 evinrude stalls at low rpm & when shifting in gear fab Johnson & Evinrude Outboards 7 May 23rd, 2008 01:12 PM
93 evinrude starts in gear bcpark01 Johnson & Evinrude Outboards 4 August 8th, 2007 10:23 AM
'93 60hp evinrude won't start after warm rgeno Johnson & Evinrude Outboards 3 March 13th, 2005 08:59 AM
'93 60hp evinrude won't start after warm rgeno Non-Repair Outboard Discussions 1 March 13th, 2005 02:35 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
