Re: Tilt Trim Problems
... hiya jim,
well thats not good. what yr Force? if you replaced it just last year should be good as gold. did it hold ok then? did you replace it as new or some other used part off fee bay? i need to ask the obvious. did you fill it with 30 straight wt motor oil, i think about 1/2, 1/3 quart? little at a time work it in and cycle the o/b several times. these little motors are pesky and sensitive to work on. pop on over to the Force Chrysler Outboards section of the forum and read a few posts and seek some guidance from RRitt. a guru on this topic.
good luck
__________________
86' Capri 1950 BR
Force 125hp
Desert Southwest
