Re: motor tries to start when trim is lifting
Have you owned this rig for some time, and did it function properly in the past, OR, Is this rig new to you, and has this problem been present since day one?
Turning key, hear beep, then later okay...... loose cable connections OR tight but dirty cable connections. Remove, clean thoroughly all cable ends and their related terminals, then tighten securely.
Engine cranks over when PTT "up" button is depressed...... Besides applying voltage to the "up" relay setup of the PTT controls, you are also applying voltage to the starter solenoid. This is a wiring problem not associated with the normal engine wiring.... I would assume that someone has connected a wire improperly.
