  #1
Old May 31st, 2009, 01:24 AM
prudenceisland's Avatar
prudenceisland prudenceisland is offline
Smile 86 4 hp evinrude carb diagram
I pulled my carb apart to unstick the choke that was froze and now I have no clue how to set the float level, and really I'm pretty in the dark all together. I took a few days to figure out how the choke assembly works, but until I know how the pin is held in place, I'm stuck.
I did get some responses on my other post, but I'm not sure if the answers applied to this motor. I'm confused because I'm told that there was a wire or something similar that held the pin in place on the floats arm.The thing is there is a hole in the floats arm that I can't figure out a purpose for because the hole does not line up with the hole the pin is suppose to go up into.
The only piece of the carb unaccounted for is a peace of wire that has an id tag attached to it. Could this be the missing link?
well I need a diagram, if someone could show me a diagram of the assembly , specifially the float section, I would greatly appreciate it.
thanks, the motor has low low low hours on it and it incredible for its age, I bought it for 50 bucks and can't believe my luck.
thanks.
  #2
Old May 31st, 2009, 01:33 AM
Whoopbass Whoopbass is offline
Default Re: 86 4 hp evinrude carb diagram
http://shop2.evinrude.com/ext/index....51673d36448a16
Submit outboard info on the left of the site.
The id tag wire is not the missing link.
Here's an idea........Take the carb to your boat dealer that deals in Johnson parts (most do) and ask them what part you need then order it from them.
Ask them how to attach the part as well.
Your problem is so easy to fix they can explain it to you in 5 seconds.
  #3
Old May 31st, 2009, 08:12 AM
mafhuntfish mafhuntfish is offline
Like you were told countless times at AOMCI - The 1st thing you should do is to buy a repair manual that covers this motor. Even if you get a Seloc manual that covers several different models & years - it would be better than nothing & you would have the diagrams you need to sort things out. It would be the best $25 you ever spent ......
  #4
Old May 31st, 2009, 10:02 AM
jonesg jonesg is offline
definately,
www.outboardbooks.com
get the real factory book though.
  #5
Old May 31st, 2009, 10:08 AM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
Quote:
You can buy a lot of toilet paper for the price of a Seloc or Clymer manual and it is far more absorbant. Get a manual, Yes but get an OMC manual. Worth every penny.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #6
Old May 31st, 2009, 10:24 AM
I agree with you 100% on the fact that the factory manuals are far better, in fact I have several. I also have several Clymer & Seloc manuals. No disrespect intended but, any information is better than no information. This poster stated in another thread that he didn't want to spend the money on a manual - I thought that a cheaper manual might be in order. It would at least give him a clue & with a little common sense, a lot of the information he needs. Just MHO .....
  #7
Old May 31st, 2009, 10:32 AM
kenmyfam's Avatar
I don't disagree with you on the "any info is better than none" thing. You just get what you pay for.
__________________
  #8
crxess crxess is offline
Look at pic.
http://www.myoutboardparts.com/files...oaded/7094.jpg
Small loop clips to valve.
Large loop slips across float arm.
Hole in Float arm is NOT important. Creates a flex area on arm.
If this doesn't help, box up and go see dealer.
  #9
Old May 31st, 2009, 05:36 PM
thanks for the help.
i am going to need someone to do it for me or demonstrate. I can probable find somebody to work on it for $20 / hour until its running if I'm lucky.
seriously your right it probably is an easy fix and im the moron who thought i could throw it back together without help. once this problem is solved though i will be able to fix these things soundly. ive don't a lot of other things to these motors and im pretty handy with a wrench.
anyways, i do have a new problem that should be simple. i think my shear pin snapped today when i was on the water and hit a rock with my prop.
it just spins in place. anyone??
  #10
Old May 31st, 2009, 05:42 PM
tx1961whaler tx1961whaler is offline
Sounds right. Take off the prop and see.
  #11
Old June 1st, 2009, 10:32 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
you can see any diagram of that motor here, but to do service correctly, you need a service manual. it not you pay the man to fix it. http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
read this, http://forums.iboats.com/showthread.php?t=244013
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #12
Old June 1st, 2009, 11:23 AM
ill fix it without a service manual. there are free service manuals available online just look for them.
there is more than one way to skin a cat and until i need a manual i won't buy one.
cheap is not the word, its called monetary efficiency.
Last edited by JB : June 1st, 2009 at 01:59 PM. Reason: Rude and insulting comment.deleted
  #13
Old June 1st, 2009, 11:32 AM
EDIT: Rude insult deleted.
Wow
I also use the net all the time to find answers to not so obvious issues. However, time is money and I also keep manuals at the ready for more often needed information.
Use of any and all available resources is the wisest move.
  #14
Old June 1st, 2009, 04:26 PM
Big Al 224 Big Al 224 is offline
prudenceisland
For someone that is so smart that help set up this website; and may I quot what you wrote in another forum
"banned and shipped off to iboats. a website might i add that was of my own creation. yes a unique website indeed. unique"
Yes these are your own words
You should are needing a lot of help. Also for someone that set up this website you sure are cheap.
  #15
Old June 1st, 2009, 07:07 PM
kenmyfam's Avatar
Having got the motor for 50 bucks it could well be worth the investment for a manual.
__________________
  #16
Old June 3rd, 2009, 07:36 AM
This guy is full of it...How did he run his motor when the float is not installed in the carb.
He is just jerking everybody around for his kicks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
anyone have a electrical diagram for a 86 mercruiser? lime4x4 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 May 16th, 2008 11:14 PM
Looking for a carb kit for a 86 evinrude v4 vro ilive4this Johnson & Evinrude Outboards 4 July 22nd, 2006 09:31 AM
86 25 hp, where to get used tiller handle and carb? ntoracn@yahoo.com Mercury & Mariner Outboards 2 July 1st, 2005 02:31 PM
86' 60 hp merc carb kit part # verification Brett63 Mercury & Mariner Outboards 3 June 24th, 2003 04:53 PM
'86 Johnson 5-8hp carb diagram JPDP Johnson & Evinrude Outboards 0 October 25th, 2001 11:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
