I have come to a channel marker. This motor has been moved to a different hull with a different harness. I have new fuel. New fluids and filters. Checked the plugs, clean, except #1 was discolored. The injectors have been sent for complete service and reinstalled. The odd bank had poor flow, per the report. The VST was cleaned, the screen had some "sandy" debris in it, no gunk. The previous time I cleaned the VST screen it had gunk and the "sandy' debris. I have not checked the fuel pressure. I will get the gauge and check this weekend to rule out some issues noted in the other forum posts. I will use the old harness to rule out any harness issues. The problem: The motor runs to a max range of 4300-4500rpms WOT with or without load. I think I noticed detonation while under load, not sure. Please advise.
