  #1
Old May 30th, 2009, 06:44 PM
shep65 shep65 is offline
Default Evinrude 4hp 2 stroke won't start
High,
I have an Evinrude 4hp 2 stroke that won't start. Has spark on both cylinders. seems to have compression. Have cleaned the carb, though jets were loose, don't know jet settings. Petrol is clean and flowing to float chamber, all fuel lines seem clear; fuel is from gravity tank on engine. Had it running for about 30 seconds after many pulls of cord, but died out and won't restart. Have repeated carb clean and fuel line checks. Can anybody advise please?
Model is BE4BRLETB
Thanks,
Shep65
  #2
Old May 30th, 2009, 09:14 PM
JB's Avatar
JB JB is offline
Default Re: Evinrude 4hp 2 stroke won't start
Check the Top Secret file (top of the listing) for "Outboard won't start" and for setting jet needles.
__________________
RED SKY at night. . .
JB
  #3
Old June 13th, 2009, 02:42 PM
Sorry JB, can't find jet info. Situation so far,, tried new clean fuel and new plugs NGK BRH6S compatible to Champion QL77JC4 as far as my local supplier can ID. Still won't fire! Purchased a manual, lots to read. Sprayed fuel and even Bradex Easy Start direct into carb, still won't fire. Definitely getting fuel through. Can anybody advise setting / position for main jet and pilot screw, accessed from float bowl? Gather from manual this engine is fixed timing, electronic ignition, so no points etc. Engine has run for a few seconds previously, so presume it's not a timing issue; but can't get anything now. Rebuilt a few 2 strokes over the years, never had this amount of reluctance to start unless timing was way off or crank bent. Fuel is burning, checked by positioning plugs just outside holes, can get flash or flame depending on setting of main jet, bit of a severe test! Grateful for any further advice before I start major strip down. Thanks, Shep
  #4
Old June 13th, 2009, 03:47 PM
Vic.S's Avatar
Vic.S Vic.S is offline
"Adjusting carbs" in TD's "Top Secret File" Pinned in second place at the top of the "Johnson and Evinrude Outboards" index.
Several other items there that may be worth reading.
BZ7HS-10 are the NGK equivalent plugs but BR6.... is one grade hotter and is resistively not inductively suppressed. Use the inductively suppressed plugs, the Champion "Q" ones or the NGK "Z" ones, with CD ignition not the resistive suppressed "R" ones. Wont explain your no start though.
Don't use starting fluid ... no oil ... spray fuel mix instead.
You only have an idle mixture adjustment . Prominent position above the air intake.. but I think you have to remove a plug from the air silencer to get at it. Main jet not adjustable! Nothing to adjust in the float bowl apart from checking float level.
Check sparks. Check compression.
Possible that flywheel key has sheared and put the timing out but would only be likely to occur if run without the nut being correctly torqued
__________________
If it aint broke dont fix it!
If all else fails read the manual
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replacing 1975 Evinrude 4HP 2-stroke. What 4-stroke is equivalent? bob marco Non-Repair Outboard Discussions 7 October 7th, 2008 05:53 PM
Mercury 4HP four stroke 2004 - doesn't START - Help nubika Mercury & Mariner Outboards 6 August 23rd, 2008 08:24 PM
1989 4HP Evinrude Won't Start ransbach Johnson & Evinrude Outboards 2 September 2nd, 2003 06:48 PM
4hp evinrude will not start cungaman Johnson & Evinrude Outboards 6 May 25th, 2003 04:23 PM
1992 Evinrude, 4hp, 2-stroke, breakerdistans Marian Johnson & Evinrude Outboards 3 June 22nd, 2002 06:40 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
