  #1
Old May 30th, 2009, 03:44 PM
ArmorLite ArmorLite is offline
Default 73 Chrysler 35hp running rough w/harmonic surge. Help
Hey everyone, thanks for taking my question. I have a 1973 wards/chrysler 35hp on a 14' wards fiberglass hull, 600 pounds dry wieght. Engine hard to start when cold, but choke selonoid is missing so that solves that problem. Easy to start once its warmed up though.
Once running and warmed up at idle, it will chatter (like a single misfire) and the engine will jerk slightly (like the kill button was pushed for a split second) then it will resume normal operation for a few seconds, the repeat the misfire. At mid throttle the engine will run slightly rough and send a constant vibration thru the whole boat. at WOT under load the engine has a slow throttle response and has a harmonic surge once it gets up to speed, like 2 guitars playing the same note thought slightly out of tune with one another,(whum whum whum) about once every second. The boat will not plane out.
Max RPM is only 2100 at WOT in gear. Carb is clean, new fuel and tank, new spark plugs and both appear to be firing normally now although it had a dead no2 plug when I got the boat, impeller working fine pumping plenty of water. Timing advance appears to be working normally with no signs of tampering or previous adjustment.
I'm thinking
Bad points or weak condensers
Cracked points wires near the stator assy.
spark plug wires leaking
Coils leaking
Other cracked ignition wire causing intermitent break
Low compression in one cyl. (please no)
Anyone have any suggestions as to the most likely candidate or other ideas?
Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
73 chrysler, 70 hp Help!!! crappiekid Chrysler 1 June 23rd, 2009 05:14 PM
'73 Evinrude 65hp running rough. magicnov Johnson & Evinrude Outboards 4 August 6th, 2007 10:20 PM
rough running chrysler am Force & Chrysler Outboards 8 March 3rd, 2007 07:38 PM
'73 Chrysler 35hp not starting scottbram Force & Chrysler Outboards 7 August 13th, 2006 11:00 AM
rough running Chrysler AtlDawg Force & Chrysler Outboards 12 September 29th, 2003 07:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
