  #1
Old May 30th, 2009, 07:19 AM
pete71452 pete71452 is offline
Default 1982 celebrity 350 cdi 260 hp
Have lost fire on #5 and #7 plug sense then have replace cap,wires & Plug and still no luck. There is no spark from plug no matter what I do. Some one told me that the wire from starter to coil may be shorting out causing the lost of spark on one or more clyinders. The wire are all in a loom and taped up is there any way to trouble shoot this. Thanks
  #2
Old June 15th, 2009, 10:04 PM
My-SS's Avatar
My-SS My-SS is offline
Default Re: 1982 celebrity 350 cdi 260 hp
You said you replaces the wires.
So 1st, double or triple check the firing order.
1-8-4-3-6-5-7-2
If that's ok
remove the cap and try to move the main distribtor shaft side to side..should be very little side movement...IF there is movement, the distributor bushing are worn out..replace distributor..
the pick up coil could be defective ..maybe from worn distributor bushing???
Hope this helps
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1982 celebrity 350 cdi 260 hp pete71452 Celebrity Boats 0 April 23rd, 2009 05:32 AM
Mercruiser 260 HP 350, octane requirement? cadunkle Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 September 29th, 2008 05:22 PM
Oil pressure for mercury (GM 350) 260 hp alpha 1 drive ernaldamerican Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 July 30th, 2007 09:47 PM
350 Chevy Celebrity Wiring kjodes Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 June 30th, 2007 09:36 PM
Mercruiser 5.7L (350 CID), 260 HP spark plug replacement HenryBoat Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 July 21st, 2006 10:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
