  #1
Old May 29th, 2009, 11:02 PM
roderunner roderunner is offline
Unhappy 1981 mercury 175 hp power loss
I am new to the outboard world but have been a mechanic for 30 yrs. I am having a fit trying to get this 2 stroke thing. I have a Mercury 175 hp that was running fine and it just lost power. It idles fine but don't dare give it gas. I have changed the stator, both switch boxes, rectifier, all three carbs, fuel pump, new fuel tank and hoses and fuel filter. I have 115 psi compression across the board. I ran it without the air box and noticed that while I applied the throttle the fuel would start spitting out the carbs. if I tilt the motor upward it would pick up some rpm's. It idles good, It loads up on fuel as I accellerate. So any help would be appreciated. Oh and I have tried new spark plugs also.
  #2
Old May 30th, 2009, 12:15 AM
Karl_Childers Karl_Childers is offline
Default Re: 1981 mercury 175 hp power loss
When you changed the stator, is it posible you damaged/sheared the flywheel key? Fuel spitting out the carbs leads me to believe you have the carbs out of whack, might want to go through them again. Why did you change the switchboxes and the stator? Did you check for spark? Do you have good spark? Spark pluggs can be bad right out of the box, as you probably already know. Throw some new pluggs at it, as 2-strokers eat pluggs and read the old pluggs and let us know what you find
  #3
Old May 30th, 2009, 12:12 PM
j_martin j_martin is offline
Like he said, basic things. It has compression, so that's good. It idles fairly well, so the reeds are usable. Does it have strong spark on all 6? How about the linkage and ignition timing. (link-n-sync procedure).
The formal link-n-sync procedure will usually uncover basic problems. If something doesn't drop in where it should, you can usually figure out what's causing it. For instance if it won't idle with the carb butterfly's shut, there's trouble in the idle circuits.
If I had to guess, your problem is something basic is wrong with all the carbs, (mechanic's error) or the linkage isn't progressing properly, or the timing is off.
These 2 poppers are pretty simple compared to a modern 4 stroke.
hope it helps
John
  #4
Old May 30th, 2009, 12:15 PM
CharlieB CharlieB is offline
The biggest difference between outboards and the ring-ding dirt bikes of old is the reed valves in the intake, which prevent the backflow of air thru the carb as the piston comes down, pressurizing the crankcase.
If a reed valve fails then crankcase air can spit out the carb, this air movement also re-carburates, adding more fuel, and on the inflow again adds even MORE fuel, flooding the cyl and killing the plug.
Inspect the reed valves for any cracks, splits, or chips. Hold them up to the light to look for a good seal, a slight gap about the thickness of a sheet of paper (.003) is all that is allowed as crankcase pressure should close that completely.
  #5
Old May 30th, 2009, 12:24 PM
John's right, if it idles fine then the reeds are probably fine.
The other great difference between the 4 stroke that you are used to and this 2 stroke, is the lack of an accelerator pump or enrichener for fattening the fuel mixture as the throttle opens.
The 2 stoke idle mixture is set fatter than best idle, like the 4 stroke.
Reset the idle to best idle IN GEAR while on the water, then further richen the mixture almost 1/8 turn.
Any lean miss, hesitation or throttle bog shows a need for more idle fuel mixture.
  #6
Old May 31st, 2009, 12:09 AM
the carbs have no idle air adjustment they are replaceable jets so would I go up or down to fatten the fuel? I am going to set the link and sync and ensure that it is timed corectly. The flywheel don't use a key it has the double spline. I was told by a local marine shop that they were sure that it was the stator. As fore the switch boxes ignorance is all I can say about that. Or maybe it is the sign of a desperate man LOL. I will check the reed valves I have the repair manual and it gives you the gaps. Thanks for the advice I will let you all know what I find out. I will put in a fresh set of plugs. I have two sets of carbs and they both do the same thing. Good idle no power. one time it actually got on plane and ran okay so maybe the timing is the answer. Got my fingers crossed.
  #7
Old May 31st, 2009, 01:30 AM
That stator has two sets of ignition windings, low speed and high speed.
Low output on a high speed winding will idle fine, and even run up NO LOAD RPM, but bog under load.
Download the free Ignition Troubleshooting Guide from CDI found thru the links at www.rapair.com
Find your model then follow the steps to test.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 1981 inline six power loss simn20 Mercury & Mariner Outboards 3 August 28th, 2006 09:55 AM
1981 70 hp Evinrude loss of power wmickens Johnson & Evinrude Outboards 1 May 29th, 2006 06:36 PM
mercury 175 power loss chevyballer Saltwater Fishing 1 October 6th, 2005 08:52 PM
loss of power 1981 75 hp mercury ob mercrude Mercury & Mariner Outboards 3 December 28th, 2002 03:34 PM
1981 70hp Mercury Loss of power swofford Mercury & Mariner Outboards 0 June 5th, 2002 11:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
