I have a 1998 115 mercury that will not go to wot on all cylinders but idles fine. I can put it in reverse and rev up the engine and then go back in gear and it will run up the lake and is fine. but problem is when you back off and then throttle it back up it does the same thing, I know this engine fires on only two cylinders until the rpms come up and it acts like they are not firing. I have cleaned the carbs and run a external fuel tank and hose to see if that was the problem but with no luck.
