1977 6 HP Johnson Engine Cowl needed
edprod
I need to know where I could find an engine cowl for a 1977 6 HP Johnson.
CATransplant
Re: 1977 6 HP Johnson Engine Cowl needed
They show up pretty frequently on ebay. You could also find one at an outboard wrecking yard, like www.tcoutboard.com.
You might even try some local outboard shops. They may have one from a junked engine.
Finally, I think there are probably several years around your model that will fit. That engine was around for a long time, and they probably didn't change the physical dimensions all that often.
edprod
Thank you very much for the information.
