  #1
Old May 29th, 2009, 10:52 AM
CaptainKev CaptainKev is offline
Default Re:Trim Tabs on a 2008 Regal 2400
I'm contemplating installing Bennett trim tabs on my 24 foot Regal. The boat weighs approx. 6,000# loaded and has the 5.7 Volvo GI with the Penta Duoprop setup. I've contacted Bennett and their suggestion is 16" X 12" tabs with 1" up fins mounted on the transom pocket for the outdrive. The pocket for the outdrive is approx. 48" across. The "normal" place to mount the tabs (close to the port & starboard chines) is not feasible because the straightest section is less than 9" across. I do a lot of relatively slow speed tubing and I would like to get the bow down sooner for safety's sake and fuel consumption. Any comments, or advice would be welcomed.
Kev.
  #2
Old June 9th, 2009, 10:25 AM
Mischief Managed Mischief Managed is offline
Default Re: Trim Tabs on a 2008 Regal 2400
I would take Bennett's advice. I think you'll be quite happy. I love the Bennetts on my boat.
Put the switches where they can be reached comfortably while sitting or standing, even if it means installing more than one set. My are hard to reach when standing and when running in rough water, I adjust the often and always drive standing. I will be adding a second set of switches soon.
  #3
Old June 9th, 2009, 02:57 PM
Thanks Mischief.....I wondered where you had gone? The decision just got easier because the sender unit on my out drive crapped out this weekend. Since I also stand, switch placement will be critical. Have you considered Bennetts Auto Control? The main drawback I have with it is that you need to install individual switches, as well. It would seem to me that that having the auto with manual override built in would be a logical design criteria...but the rep. sounded stunned when I asked if that was in the works. I am short on room on my helm, so I'm going with the switch and LED display option. Your advice is always good to get. Thanks for the reply
Kev.
  #4
Old June 11th, 2009, 09:37 AM
I have never considered auto control. It's easy enough to occasionally stab one of the buttons if simply trying to keep the boat level. The times I need to make adjustments constantly are when it's rough and I'm trying to fine tune the pitch of the boat, fore and aft, so that the bow splits steep waves nicely, but does not dig in and take water over the top. It's a balancing act between throttle, tabs and drive trim. Auto control would not help much there.
If you want position indicators, the Bennett senders are NMEA 2000 compatible and can connect directly to a Lowrance LMF 200. The LMF 200 and fuel flow sensor (<$200) can easily replace your OEM gas gauge (that's what I did) giving you fuel flow data and a vastly more accurate gas gauge, while also displaying tab position, and with the addition of other sensors, scads more data. The LMF 200 displays the following data (with proper senders): paddlewheel speed, GPS speed, tachometer, battery voltage, alternator voltage, engine temperature, water pressure, engine oil pressure, fuel pressure, boost pressure, transmission oil pressure, atmospheric pressure, temperature, depth, engine loads, engine hours, fuel flow, fuel economy, fuel remaining, fuel used, fuel range, trip fuel used, seasonal fuel used, engine synchronizer, fluid level, GPS position, trim tab position, engine trim position, and engine alarms and warnings. It's pretty kickass and cheap.
  #5
Old June 12th, 2009, 01:48 PM
Your needs do indeed make the automatic system unnecessary. Since there is no look ahead capability, by the time the data gets transmitted to the tabs you're already in trouble. The gauge you mention is way cool. At the moment I have a Garmin GPS/Fish Finder that I'm not very happy with. The map interface for my local lakes is terrible. The boat GPS location & speed is probably accurate but the graphics show me in the middle of a farmers field when I'm 2 miles out. Also, the transducer is inconsistent & craps out a lot. I was in the field of testing prototype jet engines for 15 years......so bad data really ticks me off. As I mentioned, most of the boating I do is on local lakes. I would certainly be in the market for that system if I can persuade the spouse to try try the Great Lakes sometime. I'm guessing from your location and the wave action that you spend most of the time in the Atlantic. One of these days I'll get out there.
Kev.
  #6
Old June 13th, 2009, 09:19 PM
Most of my time is spent on the bigger lakes in New England. I do go out on the ocean, but it's the steep, closely-spaced chop on the lakes that's most troublesome. Big swells on the ocean are not a big deal.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The Best Trim Tabs for Regal 2150 LSC (non Hidraulic) makbat Boat Topics and Questions (not engine topics) 4 June 15th, 2009 09:47 AM
Trim Tabs (Smart Tabs .vs. Instatrim or Bennett) MN86_4winns Boat Topics and Questions (not engine topics) 21 May 28th, 2009 10:23 AM
Regal 2400 bow cruiser battery problem jwbehm Regal Boats 1 July 25th, 2007 10:43 AM
Smart tabs on Regal Fastrac hull Regal LE Boat Topics and Questions (not engine topics) 17 June 28th, 2006 04:09 PM
Bennett Trim Tabs and ATC vs Smart Tabs reference123 Boat Topics and Questions (not engine topics) 7 July 18th, 2005 03:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
