2002 Johnson 90hp stalling when I try to plane off
LVNTHEWATER
I have a 2002 90 hp Johnson that is stalling at high RPM's. It started giving me problems last weekend so I figured that I had water in the fuel tank since it is an interior tank. I replaced the water separator filter and it seemed to be running good for a little while. I did not know if there was another fuel filter that is attached to the motor itself that needed to be changed. I have replaced all of the spark plugs about a month ago. I have since drained the water separator filter and it had maybe a teaspoon of water in the bottom of it. It does not have a problem at idle. It will bogg down and every know and then it will seem like it is going to be OK and then do it again.
Any help would help!
Thanks!!
:confused:
tashasdaddy
Re: 2002 Johnson 90hp stalling when I try to plane off
clogged carb jets. fuel restriction,
LVNTHEWATER
Thanks!!
Is there a spray cleaner that will work to fix this? If not what are my options to clean the carb jets?
Thanks for the help!
