  #1
Old May 28th, 2009, 10:33 PM
striderboat striderboat is offline
Default yamaha 115 acceleration problem
Just put boat in water after winter. Ran well for about ten minutes then purposely slowed down to 8-10 mph for 15 minutes (no wake zone). When tried to accelerate engine would run good up until about 3500 rpm's after that the engine would not accelerate and would slow down when increasing throttle. Runs fine at low rpms. Tried the next night same problem rpms increased to about 4200, if the throttle is increased the engine would slow down tojust under 4000 rpms and the rpms would go up and down about 400 rpms.
115 Yamaha 4-stroke 2002 (330 hours)
Prior to winter mechanic winterized boat, replaced thermostat, fuel filter, etc and used valve-tec decarbon. showed codes for eng to cold and shift switch.
Had to recharge batteries prior to putting in water. They may not be fully charged.
Mechanic said I should run the boat to see if it cleans itself out, any thoughts?
  #2
Old May 29th, 2009, 12:28 AM
Casco Bay Outrage Casco Bay Outrage is offline
Default Re: yamaha 115 acceleration problem
Was the fuel fresh or last year's? If last years, was it treated? Do you have a water separator filter?
Sounds like bad gas and/or clogged fuel system, i.e. VST, injectors. There are several active threads. Do a search on F115 and VST.
__________________
1991 Boston Whaler Outrage 17
2003 Yamaha F115
  #3
Old May 29th, 2009, 12:54 PM
Filled it up before winter, gas was treated, there is a water seperator filter
Thanks wil do a search
  #4
Old May 29th, 2009, 01:56 PM
cousinabe's Avatar
cousinabe cousinabe is offline
http://forums.iboats.com/showthread.php?t=299466
  #5
Old May 31st, 2009, 09:17 PM
Thanks for the info, the problems seem very similar. Took the boat out a couple of times this weekend and the performance is improving. Originally I could only get a steady 3,500 rpms WOT would bog down rpms would decrease. last time out could get steady 4800 rpms would still bog down with wot. Max speed about 28 mph two years ago it was running at 40 mph, last year max speed was about 35 mph.
Based on the old threads what is the estimated cost to have mechanic repair, filters and send out fuel injectors ?
  #6
Old June 1st, 2009, 06:29 AM
$400-$600
__________________
2003 Yamaha F115
  #7
Old June 3rd, 2009, 12:22 PM
Just dropped the boat off at the shop. Technician checked the fuel pressure and said it was good, everything that was visible looked good.
Is suggesting that I have the VST filter replaced and the injectors sent out for cleaning. His rough estimate on cost $750, you mentioned $400-$600 and he stated that he could not gurantee that this would solve the problem. Based on the symtoms he believes it will.
Any thoughts.
  #8
Old June 22nd, 2009, 04:28 PM
Smile Re: yamaha 115 acceleration problem
Just got boat back from the shop, replaced the vst filter and sent the injectors out for cleaning cost $850. Viewed the old VST filter it had some small particles.
Boat is running great, hope it continues. I believe the bill is high but my options were limited. Thanks for the help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha, 2002 4 stroke 115 stalls on acceleration tonyv138 Yamaha & Suzuki Outboards 3 December 30th, 2008 01:22 AM
2000 Yamaha F100 Start/Acceleration problem. diveextreme Yamaha & Suzuki Outboards 4 July 27th, 2004 01:08 PM
Acceleration Problem - 1992 Johnson 115 V4 dustyrector Johnson & Evinrude Outboards 1 May 31st, 2003 09:21 AM
115 Yamaha Idle/Acceleration Problem Noodler Yamaha & Suzuki Outboards 3 May 30th, 2003 08:47 PM
Johnson 115 Initial Acceleration Problem dustyrector Johnson & Evinrude Outboards 1 May 29th, 2003 01:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
