  #1
Old May 28th, 2009, 11:40 AM
Nick Las Nick Las is offline
Default 1989 Evinrude over heating water frm pee
I have a 1986 Evinrude 9.9 with a new water pump and thermostat. I am getting plenty of water through the pee hole. After it runs for about 15-20 minutes it starts to over heat and steam starts poring out of the small exhaust hole. When I elevate the motor so that water can inter the motor and still view the underwater exhaust, no water was coming through with the exhaust, I have tried blowing 100lbs of air pressure through the pee hole, I took the thermostat plate off and blow air through those holes. This motor has been lightly used in fresh water and there is no corrosion anywhere inside the motor that I could see when I replaced the water pump and the thermostat. Blowing the air did nothing.
Do I have a bad head gasket or something else? HELP Needed !
  #2
Old May 28th, 2009, 07:39 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1989 Evinrude over heating water frm pee
suggest you check and see if the rubber grommet for the water tube got pinched, and blocking water flow, does not take much water to get a tale tell. is tstat installed correctly.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
omc 4.3 1989 over heating duck12323 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 September 6th, 2008 03:27 PM
1989 Force 125 warm or cold water from pee hole bayamon25 Force & Chrysler Outboards 4 August 3rd, 2003 09:39 AM
evinrude- pee hole isn't shooting water in hight speed longlake Johnson & Evinrude Outboards 2 July 7th, 2003 05:34 AM
Old Evinrude 2hp-cooling water, compression, over-heating, setting carb, year bu charlie1939 Johnson & Evinrude Outboards 2 July 3rd, 2003 04:02 AM
water outlet...to pee or not to pee? that is the question, heh tallcar Mercury & Mariner Outboards 2 April 18th, 2003 10:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
